sqeuak!
sqeuak!
I have an '08 alpha with only 23k miles on it. Just the other day i noticed a squeaking noise when i would go over small bumps in the road. I tested the suspension on some rocks to see if it was making the noise and it wasnt, i also WD-40d the suspension. I thought my off road lights would be loose and rattling, so i WD-40d them and tightened them up. I dont know whats making the noise, so if any of you have any ideas, please share them because the sound is super annoying!! Thanks
Try your body mounts. I had a similar issue with a squeaking when the truck rocked back and forth. You are giving us very limited info to help your problem because a noise can be coming from anywhere. Noise travels and it might not sound like it is coming from where you think it is. But I would spray the body mounts and see where that gets you.
I don't have any pics right now but if you get under the passenger side of truck, towards the front of the passenger front door, then look up you'll see it. Just follow them all the way around, four each side I believe. You can use either silicone or lithium grease. Lithium grease does catch for dirt, etc.
