Someone please help me and give me some idea what may be wrong with my hummer.
Old 03-10-2013 | 07:32 PM
808H3's Avatar
Default Someone please help me and give me some idea what may be wrong with my hummer.
My 2007 H3 Hummer is having issues with the steering. I purchased the H3 from a dealership back in October of 2011. 22" crome rims were already installed on it. Until mid-January(13) everything was perfect. One of the tires went flat due to a crack in the wall of the tire. I had no other choice but to put one of the original tires and rims back on it. My very unintellegent self decided to keep driving it with the different sized rim and tire for about a month. The day that I was actually going to take the H3 to get the tire fixed, I encountered a problem when backing out of a parking stall. I turned my steering wheel to the right to back up and it felt as if the tire may have been rubbing against something. I had some of my co-workers check it out and they all said that the tires where not rubbing on anything. I immediatley drove it to the closest maintenence shop to figure out what is going on. They fixed the tire and then told me that they do not do maintenence on 4x4's. They suggested that there may be a technical issue in the vehicles computer system or it could be a drive shaft issue. Here are some exra details that may help you in figuring out what the problem may be. When driving straight, there seems to be no friction occuring. When I go to turn, it seems to tighten and almost makes the front end of the vehicle hop or skip. One of my co-workers checked the power steering fluid and it was a little low. He said that I could have a leak in the power steering lines and they could possibly contain some air. I obivsouly have no idea what it could be. Please feel free to ask me any questions about the situation to help you find an awnser. Thank you for your time.
Old 03-10-2013 | 11:04 PM
kyzombiehunter's Avatar
I am not a mechanic however I think I would have the wheel bearing checked the procedure can be viewed on you tube.
Old 03-11-2013 | 09:14 AM
RKSmith163's Avatar
Make sure you do not have 4 High Lock selected. If not, go through your selection options a few times to exercise the actuator motor. If that doesn't work, do a search, keyword Plastic Shift Fork. Good Luck.
Old 03-12-2013 | 02:20 AM
Toxicrider's Avatar
Running two different OD tires can do all sorts of nasty things to differentials and wheel bearings! I would have it checked out by a competent mechanic ASAP.
hmer
01-08-2015 06:36 PM
ElixirLiquid
02-17-2014 01:46 PM
trojan6768
08-04-2007 09:47 AM
dilo2001gt
03-20-2007 12:19 AM
no rush
07-25-2006 06:07 PM
