Snorkel
Snorkel
diccHi Everybody
I´m thinking about building a 1,5 foot snorkel by myself, using a 4" PVC pipe, and sticking it directly to the intake and to the air filter. I´d like to hear your suggestions about it. Is it correct or better to make an aluminium one. Or may be there is propper scuba tube that I can buy around. Which is better?
All your comments will be very helpul, because the places where I move thought, sometimes have some water in the middle of the way and I don´t want a wave to enter throught the air breather.
Thanks and al the best for you all
Antonio
[IMG]local://upfiles/4947/1292007DD6D7481AA080C8EADBF2B466.jpg[/IMG]
Antonio
RE: Snorkel
I am going to be doing the same thing. There is a tutorial out there I personally forget the link but its pretty straight forward just use a PVC pipe and silicon the ends... Just remember the more silicon you use the more perminant the snorkle will be.
RE: Snorkel
Great to know, I was thinking that for logical reasons has to work, but is better consulting all of you for your experience in those matters.
Thaks a lot, going to buy tomorrow the pipe, silicon, the paint
thanks a lot
Antonio
thanks a lot
Antonio
RE: Snorkel
what is the reason for the large snorkel? looks is one thing but if you think that you will be able to go threw more that 30 inches of water think again. the humvees have what is called a deep fording kit on them that will let them drive into water up to the windshield. if you go deeper that the 30 inches of water your exaust will fill up with water, your vent lines to all your drive trane will be under water and you only have water tight wire connectors at or below that 30 inch mark.
i have changed three engines and a couple of fans and radiators due to the customer trying to deepford their hummers.
be careful,
mike s.
be careful,
mike s.
RE: Snorkel
ORIGINAL: hummech
be careful,
mike s.
be careful,
mike s.
RE: Snorkel
Hummech is absolutely right on this.
Another issue is the dust/duckbill on the botton of the air can, this can be a water injestion point as well, no matter how high your snorkel is. Put your hand under the air can near the wheel skid plate and you'll feel it. Water can get in through the dust trap.
The h1's aren't sealed like the humvees.
