Slight vibration/skipping
I did a search on this and came up empty.
I have an 07 H3 with the I5 engine, automatic, and 60K miles. I just purchased it about two months ago and my only complaint is that occassionally at highway speeds it feels almost like it is skipping. The sensation is slight, but noticeable. It is only when cruising...if you accelerate it is smooth. It comes and goes and at first I thought it was just the road I was traveling. I'm still not certain that it is not the tires which are new Firestones. I get no DIC message.
Is this something that others have experienced?
daveboy
daveboy
1) Clean your MAF sensor with mass air flow cleaner.
2) Take of your TB and clean it very well with Throttle body Cleaner (spray some down into the intake manifold too.
3) Run a bottle of "TECHRON Concentrate" through the tank.
4) Change the spark plugs and only go with OEM AC Delco
I had the same feeling/problem with mine, sucker runs like a champ now. Although I had rough idle as another symptom (how does your 3 idle?) and Im still having a semi rough idle so will be buying a new MAF sensor soon.
daveboy
Sorry for the mis-info, just remembered that I had flushed tranny and changed filter too. Could have been that! Bought my 3 with 54k miles and did every recommended maintenance I could find on this forum
Let us know how it goes!
Kirkhayes37
02-04-2014 04:01 AM
Forsche
12-12-2011 02:51 PM
