Side marker access
Side marker access
Can you get to the side marker bulbs by pulling the grille off? When I went through inspection they said both of my markers weren't working. I checked the fuse but that wasn't it so I wonder if the previous owner unplugged both bulbs. I pulled most of the clips from the wheel well liner but still had a hard time getting to them and since I have to pull the grille to put in the Eldorado horns I bought I was hoping to kill two birds with one stone. Thanks!
Ben
Ben
the ones on the side of the fender I got threw the wheel well to put led bulbs in them. its pretty tight and kind of a pain and they are just #194 bulbs like license plates. they burn out all the time that's why I run leds.
I tried that when I put smoked markers on my last one but had no luck. I went through the wheel well that time but it seems a lot tighter now so I was hoping to be able to go in through the grille when I take it off.
Passenger side is easy just take off air filter box assy off and use the air hole to access the bulb
Driver side unfastened some clips and you can reach bulb in between plastic cover and fender..if you have a small hand like me will be easy.
Flashawd
09-16-2013 01:49 PM
