Should I be worried?
Old 09-12-2009 | 01:36 AM
OffRoader09's Avatar
Default Should I be worried?
The other night I was looking over the engine compartment of my 09 H3 I5 with a flashlight when I noticed what appeared to be a small film of oil and I mean small with black dust (belt dust and dirt) stuck to it behind and only behind the crank pully in the front of the motor. This was a very small amount and there was definitely no evidence of dripping as the bottom side of the aluminum engine block was clean as a whistle as well as the garage floor. Even if I let the engine idle for 30 minutes in the garage after a long drive, there still is not a drip on the floor or bottom side of the motor under the crank pully. I know that the oil has been changed by the dealer once so a spill may be at fault? Does this sound like a normal occurance or should I be concerned? I have 3200 miles on the H3. When the engine is turned off, can the positive cranckcase vacuum be deminished causing a micro amount of oil to seep out through the crank shaft seal for that split second? Thanks in advance for any help.
Old 09-13-2009 | 02:41 AM
skeeet's Avatar
My 2006 with 10,000 miles does not any sign of a film of oil. I would keep an eye on it and not worry as it is on warranty.
Old 09-13-2009 | 08:50 AM
Try cleaning the area with some engine cleaner. Might have to go to the spray wash and soap it good. Then check it after a while to see if it continues to show up again.
Could be something as harmless as a small spill from an oil change, or a problem depending on what happens once you get it cleaned up?
Old 09-13-2009 | 01:54 PM
Thanks for the responses, I bought some engine degreaser and will remove the small amount of oil. I will keep an eye on it and if it disapears completely than I will know that it was a harmless spill. If it does come back, I will take it in to the dealer.
Spencer_Marks
04-09-2014 02:42 PM
importkiller
11-11-2006 04:07 AM
Patrick
08-18-2006 07:57 AM
dilo2001gt
06-18-2006 07:53 AM
jsahara
26
03-24-2006 11:48 AM
