shifter knob
Old 11-30-2010 | 10:45 PM
Mare1679's Avatar
Default shifter ****
Hi
I have an '07 Tactical H3 (love it!). It is stick. I want to replace the shifter **** but I can't get it off. Any ideas?
Old 12-01-2010 | 08:05 AM
Manson75's Avatar
bump
I have the same dilemma, the **** looks ok, but there's much cooler ones out there. My last manual car unscrewed easily, and I feel like I'm about to break this one trying to unscrew it.
Old 12-01-2010 | 08:37 AM
wfturner's Avatar
I have removed my shifter and shortened it by as much as two inches.
The actual **** and most of the shaft is a serious press fit and can not be separated.
First you need to unclip the front (toward engine) part of the leather boot.
Then you need to unclip the rear two plastic clips of the boot and then you can access the allen screw.
This allen screw holds the outer shaft **** and leather boot and **** to the pin from the coming out of the transmission.
Now you may already have accomplished this and found that this shifter assembly is just about impossible to take apart, short of damaging it.
If you do find a way to remove the **** from the outer shaft, please let me know
Good luck
Old 12-08-2010 | 08:45 PM
Mare1679's Avatar
Thanks for the responses. I have no clue what I am doing so I think I will ask the pro's to take care of it.
Philster
06-24-2013 08:13 AM
locastro85
05-09-2008 02:05 PM
gregc
03-12-2007 10:38 PM
pmagnet
31
08-24-2006 11:54 PM
importkiller
05-23-2006 01:36 PM
