Service tpm?
thanks i will monitor it for a day or so-i waited about an hour & it still shows serv tpm.....dont think its the battery as the truck starts perfect...bummer.thanks again
Your vehicle only reads 4 channels on your TPMS. The early models did have a sensor in the spare, the later ones did not. In any event it will only read the 4 on the ground. Try doing the re-learn described in you owners manual. If that does not work you likely have a bad sensor. The battery another poster mentioned was the battery in the sensor and not the vehicle battery.
There is no sensor in my spare and 30psi will trigger the tire pressure light. if you increase the pressure to about 33psi it should go off. did you do a tire rotation with out the relearn? that will also do it.
