Service 4WD Light
Service 4WD Light
Hey all I'm new to the forums and to the H3s. I just bought it 2 weeks ago. Today I installed a rearview camera in it and once i reconnected the battery i now have a Service 4WD message on the dash. It was not on before the install. is this something i should be concerned about and what can i do to fix the issue without returning to the dealer?
Thanks for the suggestions. I had planned on doing that tonight as well as checking the connections on the center panel above the radio. I did a search but couldn't find anything that seemed to help me.
Seriously, make sure the buttons are all in the same outward position.. If 1 gets stuck, it sends conflicting signals to the computer=Service 4WD.... tap on all of them and make sure they all pop out to the same outward level position. if 1 seems inward, pull it out. Shut vehicle off & restart. No reason to go to the fluid, since you did nothing to the fluid to cause the light, & Battery disconnect has nothing to do with it. GL
Glad you got it corrected. Future reference: tech101 push, listen for "click", if you are unsure, lightly pull on connector, if it stays in, then it is connected, (even though I know, I still give it another push, just to make sure). I also make sure to count the connectors taken apart, and remember that count when reinstalling.
njhusker
11-04-2019 11:36 AM
ReadyGun
12-09-2013 03:23 PM
