Rpm's at idle?
Rpm's at idle?
What is your rpm at Idol. Mine runs about 500 and is a bit rough and causes a vibration in the steering wheel. When I bring it up to 1000-1500 it goes away. I did put on the air intake system that was posted to one of the forum's. Not sure that it is causing vibration at idle.
rpm's
Thanks for the reply
I would revert to stock and see if it still does it... Also when you installed were you careful in handling the MAF? Did you clean any of the MAF or TB compnents?
The I5 does have a rougher idle than alot of other engines... But if it feels as if the motor is about to stall than there's more going on...
The I5 is not inherently balanced. A straight-five design has free moments (vibrations) of the first and second order, whereas the I6 has zero free moments.
Yes, your steering wheel vibrates at idle.
rough idle,?misfire?
most net discussions of rough idle talk about actual roughness/stumbling/misfire.
i dont think the term rough idle is proper for an i5 running normally and causing a slight ,STEADY, vibration.
it is idling at a constant rpm and each cylinder is firing the same as the others as smooth as can be at a low rpm.
i think there is a misuse of the terminology.
rough idle and steady vibration are two different things.
you can feel vibrations from electric motors!!
Vibration at idle:
Thanks for the feedback on the vibration at idle. From your comments I also think it is normal. The steering wheel and engine are as smooth as glass once you are on your way.
Thanks for the Information.
