Roof Markers on the basic H3
Hi Guyz,
Wanted a quick check - can i actually install roof marker lights on my basic H3 2008? Is it an expensive & time consuming job? Can an external workshop source & do this for me [i'm from Dubai]......Wud b gr8 if someone could guide me thru experience.....tx mates!
You can buy that big overpriced wing that has the marker lights on it and hope it stays put and doesn't whistle or you can put individual lights on it like it should have from the start.
Granted with the factory kit you only have to drill two holes in your metal roof and with individual lamps you need to drill 15 holes, but once you have drilled one hole it just doesn't matter anymore after that.
Personally I like the much cleaner look of individual cab marker lamps than the factory set. Besides, save a ton of cash too, my Pacer Chevy marker lights (all 5 including all wiring and clips) was less than $50.
OK, my question is can I take the OEM roof markers off and remount them flush onto the roof without the plate? Are the existing holes for them to mount the OEM's out of place to where I can't do it? And does anyone know if I would be able to take the existing lights off of the mounting plate and use them by themselves?
Theuofmiami
09-27-2010 04:31 PM
swr930porsche
11-14-2009 09:43 PM
