Roof Marker lights
Thats 2 of us...
My end lights went out 2 days ago, my centers are getting dim so i was going to replace all the lights.....................
I called the the dealer to find out how to replace the 3 front and rear clearance lights,
they are wired with connecters Push-lock and are easy to install, BUT
There parts department says there (Get This) $151.26 a piece for the yellow fronts and $161.48 for the red rears.........Each
Hello
somthing wrong here!!!!!
The 4 corner lights are bulbs are part # 1194 at $4.50 each come off with a phillips screw-driver, I replaced these yesterday, bought at auto-zone.
Signal stat has new LED lights that look like ours with Different mounts and hookups, there lights are $8.99+ mount $4.00+$1.99 for there wiring assby...Lifetime Warrenty
I may have to redo, the clearnce hummer lights becuase im not into those prices, ill just use clear silacone to seal the lights...........
Rick H2/H3
Hello
Rick H2/H3
clearnce light bulbs are replaceable......
The clerance lights come to find out are replacable bulbs:
there are clips on the end were there is a notch, you need to run a plastic knife around the rubber on the light, then push at the notch and the clearnce light will come off.
one end of the light has a hook and the other has a spring clip, after removeing light disconnect base from bulb holder and replace the #1194 bulb,
put a small amount of clear silacone on the rubber so you wont have any water leaks and snap it back in place.........
I felt kinda stupid, after they did one for me but, oh well...........
Rick H2/H3
Rick H2/H3
30 second marker light change
I had a marker light go out on my 03 H2 and found no info on changing them. went to the dealer and they said I had to remove the head liner, they wanted a minimum of 60.00 to change one bulb . Did some more research and found it to be easier than blowing your nose on a windy day. Was going to post a video but couldn't find any way to. Just slide a flat piece of hard plastic under the end of the light housing and you should feel the clip release and just pull up gently. amazing how simple, there is a clip on one end and a hook on the other. If you tilt it up a little you can see which end has the clip on it. Mine were towards the driver side. So this tip should be worth a lot . lol Have a great day.
bobopotato
27
07-30-2011 09:09 AM
jeffwhiteis
02-06-2011 04:20 PM
H3_Hummer
101
01-08-2011 08:18 PM
CruisinCarAudio
05-25-2006 04:14 AM
