Ride Height Sensors wanted.
I do not have any but I was looking at the docs for the Rancho lift kit a couple of weeks ago and remember seeing that there are two versions. I'm not sure if they are cross compatible or not so you might want to make sure on that.
I just re-read the document and its actually the sensor links that they mention. On some the links are 4.6 inches long and on others they are 5.3 inches long. So maybe the sensors themselves are the same. I'd still double check.
I bought one from RockAutos and didnt check what Cardone "Off Road Package" meant. Its a resistor instead of a potentiometer so it fools the Air-Suspension, wasted money for me!
It was that that pushed my AS Controller over the edge, expensive mistake!
Actually I must correct myself, having successfully replaced the left sensor, I powered-up the Cardone sensor ( Pin1=5V, Pin2=O/P, Pin3=OV) and it works fine, I should have stuck with it, guess I was unlucky when my AS ECU died.
My apologies to Cardone!
mcrdeviation
11-11-2012 11:51 AM
