Replacing front wheel hub
Does anyone know of a cheap place to order the wheel hub assembly? I found gmpartsdirect @ $212. That was cheapest I have been able to find. Also, when replacing the wheel hub is it pretty much the same as the H2 in regards to removal and replacement? If anyone has a writeup for the H3 could you post it up. I plan on tackling this next week.
TIA
Deryl
TIA
Deryl
Calls for 1hr labor time.
remove wheel, caliper, rotor, wheel speed sensor, axle nut & washer,
hub bearing mounting bolts, remove wheel hub and backing plate. Clean & lube steering knuckle mounting contacts, and install new hub bearing assy. with backing plate, and all other parts removed.
Torque wheel hub bolts 133 ft lbs, drive shaft nut 173 ft lbs, wheel studs 103 ft lbs. GL
ebay has the best price around:
Front Right or Left New Wheel Hub Assembly 4 Wheel ABS 4WD 4x4 Passenger Driver | eBay
smileynialley
02-26-2015 04:15 PM
ultraclassic01
10-04-2012 11:25 AM
