Replacing all transfer case seals
Old 07-06-2020 | 11:42 AM
LatvjuAvs's Avatar
Default Replacing all transfer case seals
Hello!
2007 H3x, less than 100k miles.
BW4493 Transfer Case.
Transfer case, front output seal is leaking, if I am taking TC down, I will replace all seals, input and both output.
Only real place that ships to my location is RockAuto, wanted to confirm, if I can fit those parts on my transfer case.
Only front output seal in stock are for "Borg Warner 4485", could it fit for BW4493, or should I wait for NATIONAL to come back in stock ?
Also, both available rear output seals look different in pictures, or it does matter much?
Worst case scenario is to drop transfer case, remove seals, inspect and buy same ones based on how they look(massive downtime and hassle).
Or just buy every available one and see who fits.
Thanks for any input.
Old 07-08-2020 | 07:53 AM
Old 07-08-2020 | 08:46 AM
LatvjuAvs's Avatar
Thanks!
I was impatient and ordered everything from RockAuto.
If there will be fitting problem, will get this kit.
They do ship to my location!
I mentioned RockAuto as only one who reasonably ships to me because any other place with item worth 20$ will end up as 100$ worth item when it gets here, I used to that already.
Old 07-08-2020 | 09:35 AM
Alpha X's Avatar
Cross reference these GM part numbers for the Transfer Case Seals.
These are for 2006 - 2010 Hummer H3 Transfer Cases, Borg Warner 4493 / 4494 (NR4 / NR6)
https://www.wholesalegmpartsonline.c...ssembly=392149
Seal, Transfer Case Input Shaft: 88996656
Seal, Transfer Case Rear Output Shaft: 89059495
Seal, Transfer Case Front Output Shaft: 89059515
Old 07-08-2020 | 01:02 PM
LatvjuAvs's Avatar
Thanks "Alpha X", got top two from Rock Auto in my order.
"Seal, Transfer Case Front Output Shaft"(89059515) - that one, they did not had in stock for this number, scored one in eBay.
Thank you and have a nice day!
CarlosC
07-02-2023 10:46 AM
bigstick0000
09-17-2020 09:29 PM
HUMVEE_H3
08-06-2018 12:49 PM
thorg113
03-27-2018 08:54 PM
Donnie6983
11-19-2017 12:11 AM
Quick Reply: Replacing all transfer case seals
