Replace h3 sunroof gasket
Old 06-01-2013 | 09:46 PM
loud pipes's Avatar
Default Replace h3 sunroof gasket
Has anyone removed the sunroof to replace the gasket? It is a simple as it looks where it's just removing 4 bolts? Thanks.
Old 06-02-2013 | 07:08 AM
Broken Halo's Avatar
I don't know why you're replacing the seal, but keep in mind their design intent is to keep out debris, reduce water intrusion and cut wind noise, not be water tight. That's why there are drain tubes.
Old 06-02-2013 | 09:37 AM
loud pipes's Avatar
Replacing the seal because mine has a small tear in it, letting water come in thru the dome light under heavy rain and the drain tubes can't handle the load.
Old 06-12-2013 | 07:41 PM
nelly27281's Avatar
Would you mind if I ask from where you got it and how to change it...? as mine also got few tears on it.
Thanks.
Old 06-13-2013 | 02:58 PM
loud pipes's Avatar
Nelly, as painful as it was, I got it from the dealership. I haven't changed it yet, so no real advice on the best way to go. 4 screws hold the glass frame to the track rails, so I am going to remove those and put the gasket on the glass while it is off the vehicle.
Good luck!
Old 11-05-2015 | 04:33 PM
nelly27281's Avatar
I know it's after looooong time, but were you be able to crack it down? I am planning to do it this weekend, so thought of getting some more tips.
Old 11-05-2015 | 07:26 PM
happythree's Avatar
the service manual is fussy about the spacing of the panel so be careful getting it back in place.
it says front,.020 below the roof metal, the back, .020 above!
must be for air/water flow??
how does the rubber attach?
psych0
05-26-2010 07:31 PM
majhero
02-02-2009 11:33 AM
silverwarrior
11-11-2007 06:31 PM
H34 pleasure
44
05-04-2007 05:17 AM
