Removing the stickers on the visors??
Old 06-01-2007 | 09:26 PM
Dennis's Avatar
Default RE: Removing the stickers on the visors??
Very well said Mark...I like the elequent use of the word ****....
Old 06-01-2007 | 10:38 PM
mfish's Avatar
Well ****!![:@] Its starting to sound like I am gonna be stuck with these ugly pieces of ****!
Old 06-01-2007 | 10:41 PM
Dennis's Avatar
I can send you a couple of OU bumper stickers to put over them..
Old 06-01-2007 | 11:11 PM
mfish's Avatar
They would probably look better than whats on there now, but I'll have to go for a UCSD sticker first[8D]. Although I do need am Oklahoma shot glass for my collection
ORIGINAL: Dennis
Old 06-01-2007 | 11:27 PM
Dennis's Avatar
PM me your addressand I'll see what I can find.
Old 06-02-2007 | 12:04 AM
shortbus's Avatar
ORIGINAL: mfish
Has anybody removed the stickers on the front visors ( those things that fold down with mirrors ). Those things are just plain ugly and I would like to remove them without damaging the fabric. Anybody know a good technique??
[IMG]local://upfiles/2273/E9E18CACEA2A4466A97C8F3D7ACA5B16.jpg[/IMG]
it's just too painful to contemplate a response to this question .. . . . . . . .
Old 06-02-2007 | 06:48 AM
Crash's Avatar
Just have 'em LineX'd...
Old 06-02-2007 | 11:50 AM
Dennis's Avatar
Old 06-14-2007 | 07:59 AM
KeyzH3's Avatar
Try this,
http://cgi.ebay.com/ebaymotors/Warni...QQcmdZViewItem
Old 06-14-2007 | 08:21 AM
D VADER's Avatar
Here's how it's done guys. It takes some time as its silk screened in layers:
Here is the proper technique:
IMPORTANT: The original Goof Off - the one in the metal can, is the only product that I know of that will peel this warning label without damaging the vinyl in any way. Be sure you are using the original "Goof Off", and not "Goof Off 2", "Goo Gone", or any other sticker/label remover.
If you can, remove your visors for the entire operation.
The warning label is applied in layers, so any part of the warning label that is yellow, red, or black is significantly harder to remove than the white part. Soak part of a rag in the Goof Off, and apply the product liberally to about 1/4 of the warning label surface and rub it in. As soon as the product dries, put some fresh Goof Off on the same spot and you will see the warning label start to bubble. At this point you should be able to start to rub off the label.
Once the entire rubbery surface of the warning label is removed, soak a cotton rag in goof off and let the rag sit on the dark rectangle for a minute or two. Rub the area with the rag and then wipe it dry with a dry rag. Repeat until the residue is gone. Your visor will crinkle and the vinyl will seem very loose. At this point it looks like the visor is ruined but it is not. Once the label residue is completely removed, wash the vinyl with soap and water to remove any traces of solvent. Sit the visor in the hot sun for 10-15 minutes and the vinyl will tighten up like new. Treat with vinyl conditioner and reinstall visors. Viola - no more warning label and the vinyl is as good as new.
Good Luck!!
