Removing rear shocks 2006 H3
Hey guys, I replaced my front shocks couple weekends go (Made a video which I hope to upload to youtube soon). Now I am replacing my rear shocks and run into a small dilemma. I am not sure how to remove the top nuts. They are overlapped a bit by the shock itself and I can not figure out how to get to them with a wrench. Has anyone done these in the past and can offer a suggestion? Also do I need another wrench to hold the top so they do not spin or can I just unscrew these?
much appreciated ! I was wondering if that would work but was afraid to try to remove them and then not be able to finish the job . Do you know if I need another wrench on top to remove the top nuts? I tried sticking my finger up there to feel if there is a nut or something but couldn't. Felt lots of rust so if there is something there it might be all rusted away.
I replaced mine when I purchased my rig a few years back, and I think they were bolts that came out. The nuts are spot welded in removable clips in the upper mount. If the bolts break, you would need to install new bolts/nuts.. Spray all the threads with pb blaster and work the bolts, back and forth a little at a time before you remove them. GL
I did my shocks about 2 months ago.
The problem I had was that those clips were very rusty and snapped when I tried removing the bolts.
I ended up having to cut the bolts in half to get the shock s off.
I installed the new shocks using new bolts, lock washers and nuts.
The removal was hell, the install went smooth.
This was my exact same experience with the rear shock replacement. I had to go under the wheel well with a sawzall to cut the clip and bolt. Major pain in the A$$.
I ended up replacing the clips with grade 8 nuts and bolts.
I know this may come as a surprise to you but I am capable of learning new things ! so what I didn't know yesterday I may know tomorrow
