REMOTE STARTER
#27
RE: REMOTE STARTER
ORIGINAL: BMBEBENEAR
I have a 2007 H3 and have yet to find a remote start that works with the new system. Let me know if anyone has one up and running.
#28
RE: REMOTE STARTER
you will alwya need to buy a transponder override system in addition to the auto start unit. I like autopage 860 lcd for teh remote start unit and theIDATALINK multi series trandponder override system to bypass the PK3 security in the hummer (not passlock, h3's use the newest system gm has out called the PK3) The LCD remote start/alarm/keyless entry gives you over 1/4 mile range and unlike cheaper units works on fm frequencies so you can control all the functions while a few hundred yards away inside a store if you want. The remote start and the bypass should be around $280-$300 combined.
remote start/alarm unit: http://www.autopageusa.com/t_inside....a-5f6fd435f2ac
Transponder bypass/door lock unlock controller: http://www.idatalink.ca/viewprod.asp...5&type=car
#30
RE: REMOTE STARTER
Your welcome!
I would try to get both because they work together with a one cable hookup called a data link. This cuts the installation time in half because the two units communicate together using the cable instead of having to wire another 15-20 wires. Plus the door locks and everything else will work through your obdII port, which means you will not have to find and splice into any door lock/unlock wires. Very easy install. Basically the only wires you need to splice into are power,switched power, ignition, brake switch +,ground, and the obd port.
