reduced engine power
Old 10-06-2007 | 04:58 PM
H2's Avatar
H2
Default reduced engine power
i had my reduced engine power displayed on my dash. has any came across this problem and if so whats the problem? what part needs to be replaced? can anybody being mechanically incline replace or is it a dealer problem? thanks for the help
Old 10-06-2007 | 06:32 PM
dizzy's Avatar
Default RE: reduced engine power
Does the truck run ok? Is the check engine light on? I know that some vehicles will go into some sort of limp mode to get you home if a problem is detected.
Old 10-06-2007 | 06:34 PM
blackstangs281's Avatar
Is it still under warranty?
Get it to the dealer, it could be a number of different things
Old 10-06-2007 | 07:01 PM
Muddydawg75's Avatar
RTFM....
Reduced engine power on the DIC is due to engine overheating.... Check the coolant first....
Did you happen to look at your temp guage when it went into that mode?
Old 10-07-2007 | 09:01 AM
hilljob26's Avatar
maybe somebody should make a chart,like showing what would be the first thing to check when a certain message pops up
Old 10-07-2007 | 11:08 AM
Hilljob's making a chart! Sweet. 14G metal chart with knurled edges!!!! I think O Manuals have some charts? So H2 post back w/ an update.
Old 10-07-2007 | 05:42 PM
H2's Avatar
H2
it was not over heating when it happend but i guess i will run it down to the dealer to put it on the scanner and see what happened. its not under warranty so hopefully its nothing major
Old 10-10-2007 | 02:11 AM
If you are signed up with Onstar they can run a diagnostic for you and tell you what is going on with the truck.
Old 10-10-2007 | 06:45 PM
If it wasn't actually overheating there is a possible fuse that is bad.... I cannot find where I read what one yet...
Old 10-11-2007 | 10:33 AM
GorillaH2's Avatar
Did you take it to the dealer yet?
