Rear wheel Camber wear
![Talking](https://www.hummerforums.com/forum/images/icons/icon10.gif)
Has any body ever experience a Lil bit of of camber wear on the rear right wheels and any ideas what it may be , some said it could be bushings others that it can be the axle housing any suggestions please
well, there is a way to align. the rear. it is a pain in the *** though. I believe you have to pull the axles and shim them. A frame shop/collision repair center ought to be able to do that. Usually the rear end alignment doesn't go out of adjustment all that much unless its bent from a hard impact or collision. If your getting inside edge wear it could be camber or negative toe. If the axle is slightly shifted to the right it could cause inside edgewear on the RR and outside on the LR.
Best way to find out, take it to an alignment shop and get a reading on all four wheels.
Otis Arms
04-22-2014 03:15 PM
cmj917
09-25-2009 05:15 AM
HummerGuy
07-24-2007 03:03 PM
