Rear Hatch License Plate Trim Problem
Bros -
My rear hatch trim (for lack of a better phrase) - is coming loose. Specifically, the chrome bar across the top of the plate area, I guess it's the light housing. The left side of it can be pulled away from the hatch.
How do I fix this? Is there a clip or something that is accessible by removing the interior panel?
That is what I get for reading and typing.
I removed the inner panel, took the license plate trim off. Pick up some 2 part epoxy from Home Depot, Lowes, Menard. Mix a small portion of the epoxy just to fit the broken piece back on and let it set to harden. Next, I used a piece of heat shrink tubing, cut a piece just a little shorter than the repair part, cover the part and mix some more epoxy and then fill the gap between the tubing and the broken mount and let sit again. End result, you made a plastic cast.
i like your improvising lol
My license plate/latch cover broke also. Rather than repair or replace the broken parts, as I understand this is a common issue, I drilled 3 holes through the plastic and through the metal inside. Then I ran ss 1" bolts with washers and nuts to keep it secure. While not the standard repair I don't thnik I'll have a problem with it again, and the small bolt heads are not noticeable.
solarflare
06-25-2008 10:25 PM
HummerMike
16
01-24-2007 03:17 PM
