Rear door panel removal?
A #2 Phillips screw driver and a panel popper tool is all you need.
First remove the screw that holds the square plastic panel to the rear of door opening handle, then remove the two screws above to the rear of this panel that hold the panel to the door, then pop off the small panel extension at the top rear of the panel "no screws on this", then using the panel popper tool start removing the door panel at the bottom front edge, once the panel is up then pull the rest of the panel up by hand all around "will be tight and may break a few clips doing this, this is normal due to the age of the truck, they can be replaced", then unplug the switch wiring, then remove panel from truck, then peel down plastic water barrier from inside of door to get access to window. Done!
I’m not so good at wrighting directions so please call me directly if you need help over the phone.
motley1987
02-27-2014 07:20 PM
aaronballard0033
07-15-2012 10:51 AM
