Rear Door Markers Removal
Old 06-07-2012 | 09:41 AM
LIL-TNK's Avatar
Default Rear Door Markers Removal
Hi Guys,
Two of the markers on the rear door of my 2003 H2 have stopped functioning.
Educated guess is they burned out...
Has anyone of you ever worked/ changed such markers?
How do you get access to the bulb?
Please advise.
Old 06-07-2012 | 01:45 PM
mgurgone's Avatar
You need to use a small flat head screw driver to push the release pin on the lights and they will pop out. If you look at the black plastic housing around the light there should be a space for you to push in the screw driver releasing the light.
Hope this helps
Old 06-07-2012 | 10:30 PM
honda400ex2003's Avatar
mine lifted right out last night with a little tug on them. after they come up there is a turn locking housing that houses the bulb. this housing has the connector clip on it and can be disconnected to release the light housing itself.
194 is the bulb thats in them also, you can get them ready to go for when you change them.
the screwdriver will work to unclip if they are stuck tight. you will have to make sure they have new gaskets or are siliconed again or they will leak. i just had to fix mine last night, i hit the right one while waxing it and broke the stock seal. it started leaking so i had to fix them
steve
aaronballard0033
07-15-2012 11:51 AM
blackterror
06-21-2009 10:03 PM
Ray
03-15-2009 04:32 PM
salil75
02-23-2008 12:57 AM
IgottaH3
02-13-2007 11:13 PM
