Rear axle & diff skid shields installed on Alpha...
Old 02-24-2008, 10:04 AM
HummerMike's Avatar
Default Rear axle & diff skid shields installed on Alpha...
Well, I finally got around to installing the rear axle and differential skid shields on my Alpha. I got these through the dealer I work for and they are made by Boulder Accessories. Super easy to install. It only took about 20 mins. Very tough and should hold up quite well. Enjoy the before and after pics...
Old 02-24-2008, 10:07 AM
Bennersj's Avatar
Default RE: Rear axle & diff skid shields installed on Alpha...
They look good and solid, should be ready to hold up against pretty much anything
Old 02-24-2008, 04:19 PM
I installed them on mine along with the under carriage protection. Look they they should do the trick.
Old 02-24-2008, 05:41 PM
Hey Mike,
Nice job, they look great. Would you mind telling me how much did they set you back?
Thanks,
Gar
Old 02-24-2008, 06:20 PM
SteveO's Avatar
Now you have Peace of Mindthe next timeyou go off roading.[sm=sleeping.gif][sm=sleeping.gif]
Old 02-24-2008, 09:21 PM
HummerMike's Avatar
I got everything for $280.00. But that was using my employee discount at the dealership.
Old 02-25-2008, 05:02 AM
671H3's Avatar
Looks good!
Old 02-25-2008, 12:50 PM
Did they come with all the mounting hardware included? Do you need longer U-bolts for the shock skids? Any leakage from rear dif after removing 4 bolts on diff skid? I'm just curious, because i'm looking at getting these in the next few weeks, and was curious about installation.
Thanks in advance!
Old 02-25-2008, 02:22 PM
HummerMike's Avatar
The shock skid plates do not come with any additional hardware. You remove the 4 bolts under each shock plate and slide the skid plate on and re install the nuts. Theres plenty of thread leftover. Just make sure you support the leaf springs with a jack to hold everything in place. Thats really a 2 person job.
The differential plate comes with additional hardware. No leaking occured. Everything stayed sealed just fine. They supply longer bolts to replace the 4 you remove from the diff cover.
Old 02-25-2008, 02:44 PM
sweet! thanks!
Quick Reply: Rear axle & diff skid shields installed on Alpha...
