Randomly wont start
#21
I had the same problem, randomly not starting (2006 H3), changed the ignition cylinder and had the fuel pump filter changed or cleaned. My car has only not started once since those two things were done. They checked my fuel pump but only the filter was changed.
I have been using only the key, not the beeper thing. Was told it could also be the BCM thing, I am having that done today.
From what I read, it must be either the Ignition cylinder (which would explain why the car starts 10 minutes later, when the theft control times out) or the Fuel Pump (which would explain why this problem occurred in the mornings when engine was cold 90% of the time). The BCM module could also be a factor, not sure about this.
#23
#1 is the EVAP return line and filler vent (the little canister thing mounts in the top rear of the tank and is a purge [one way] valve) and is sold with the tank assembly.... you can see it in position on the top of the tank.
#2 is the pressure sensor
#3 is the pump cam lock ring
#4 is the fuel line
#5 is the pump module
#6 is the pump to tank seal
#7 tank assembly
#8 is the level sending unit
#8 is a wire with a connector on one end the sender that snaps on the side of the pump with a float on an articulating wire arm?
No filter.
#25
curious logic?
i had a veh that would start run fine, would NOT run warm/hot.
and i doubt if the hidden filter is the problem!!
#26
Randomly wont start
This could be your problem. The pass lock system problem. Performed daignostic system check and found B2957, current tested and found high resistance in pass lock switch in ignition replaced ing. swith HSH. reprogramed theft system and tested. This corrected the problem. This problem was on my 2006 H3.
This problem would happen sometimes. Vehicle would need to set for 10 mins. then would start. Ignition Part number 15795321. You will need to reprogram your pass lock system after you replace the ingnition switch.
#28
#29
Got a 2010 H3T Alpha 23000 mi had 6 mo. One time event of driving app. 5 mi and turning it off for app. 10 min and when trying to start all I got was the clicking like a dying battery.Lights and radio fine. By the time I got back with other truck and cables it started. Had batt load checked and starting system checked all fine. Thinking starter. If so how hard to change. Can't seem to find any manuals online.Previous posts mentioned a change in ignition system or pass lock.Would these problems have the solinoid click?
force0009
02-13-2013 02:45 PM
