RANCHO VS TUFF COUNTRY
RE: RANCHO VS TUFF COUNTRY
I may actually have something to contibute to this one, just spoke with both the Rancho and Tuff Country reps yesterday.
After speaking with both, my personal pref. would be the Tuff Country and my reasoning behind that is that the Rancho lift DOES require cutting of factory brackets in order to install. Neither one requires any kind of welding. If you do not want to have to cut go with Tuff Country if your not worried about that then it is again a personal pref.
just looked at the Tuff Country spec and pricing sheet they say they will fit a 36" tire. BUT after speaking to both the Rancho and Tuff Country sales reps at a show this past weekend neither would recommend the 37's both said the truck doesn't have the power (they were on both show trucks 37's) Go with 35's
ORIGINAL: w3sCiH3
i cant find a 35" tire that fits a 24" rim. Well I have the 3.7L motor, plus 5 speed standard so more power handling, you think ill be able to pull it off?
http://www.kumhousa.com/tires/light-.../KL71/specs.do
Toyo Open Country A/T LT325/50R24P/N-301450 Rim Width-9.0-10.0-12.0Dia-36.7
Theres not that much lifted Hummer Here in Hawaii, and pictures on the internet dosn't show much, what do you think i should go cause im going with a 4" Tuff Country Lift and I want Asanti Rims either , the Rims size range from 19"-24" and also what size and stlye tire should i get?
http://www.sleekmotoring.com/images/asanti/AF143big.jpg
southernH3
11-18-2009 03:38 PM
Black.is
10-13-2007 05:47 PM
