Radio won't shut off with ignition after battery swap
Greetings - I just got a 2006 H3 - seems ok - few issues here and there but nothing major yet. I swapped my battery the other day and now find that my radio doesn't shut off like it did prior to that (with ignition). I've read some other things not specific to the H3 that seem to indicate there could be some type of 'reset' such as turning the steering wheel, rolling the windows up and down, etc, but wonder if anyone knows what to do specifically with the H3?
I did do a forum search but didn't see anything - thank you in advance for any help/advice!
BC
BC
BC
BC
![Wink](https://www.hummerforums.com/forum/images/smilies/wink.gif)
Retained Accessory Power (RAP) when working properly keeps the radio on for up to 20 minutes after the key is turned off, or until a door is opened. In other words, it is working correctly now, before it wasn't. There are no adjustable settings for RAP with H3/H3Ts
That is because you had a RAP glitch before you replaced the battery, probably because the prior owner did not bother to replace the OEM piece of crap battery terminal connectors.
Get rid of those ASAP, first mod you should do.
Thank you Doc - I'll look into swapping those connectors out and test the 20 minute theory. Just wanted to make sure it was going to shut off at SOME point.
Thanks much for your help,
BC
Well, I had an aftermarket stereo put in because I wanted Bluetooth and iPhone capabilities and everything is working as (in my mind) it should. When I turn the H3 off, the radio shuts off now as well.
I really appreciate you guys taking the time to read and help me out - still going to look at the terminals as well as the door switch and really start reading thru the forum to learn as much as I can about my H3 - I dig it - it's a cool vehicle!
BC
BC
GuestWho
02-06-2012 07:23 AM
bayrat394
01-23-2011 04:30 AM
