Radio Panel Removal
I have a 07, I don't know your model year, but it should be the same
The entire brushed aluminum panel is held in place by spring clips
Put your fingers in the two 12V charge holes at the bottom (to give you a place to grab) and pull straight toward you
It takes a good pull. It should release from bottom first and then you can grab the side and release the top part
Careful, there are wires that are connected to the back, you must disconnect those next
hman969
05-12-2008 02:13 AM
