rack and pinion boot leak
Did they show you were the leak was have you spotted the leak your self?
What i did was replaced the whole steering system since i damaged the pump and hoses because the rack was bad haven't had problems since then.
If you need any help changing any parts let me know here i will explain step by step since i did it so many times because those parts i kept buying were from autozone and o'raillys, i recomend napa they make the best parts.
its been 6 months since i replaced everything I haven't had a problem since then.
I think the shop is trying to screw us over as the only oil I see is from the recent oil change on the rack and pinion. In Maryland the you only have to go through state inspection once so the shops always try to screw you over.
I will clean everthing up to see if it is leaking and get back to this post. My H1 was wet for the 10 years I owned it.
autobots
02-21-2017 03:09 PM
mthoodh3
12-05-2016 10:53 AM
DirtyH3
10-04-2015 11:31 AM
