PROBLEMS WITH H3
#31
RE: PROBLEMS WITH H3
$30 for oil and filter and add any fluid needed and a carwash i heard the H2 where $50 and up but the H3 just the colordo basic motor on my 4 runner it was $27 for oil and filter and any fluid that need to be add and greased
#32
The crack is on the plastic part..as you follow the plastic molding from the front of the roof to the back as it dips down its right on the bottom part of the dip. Hard to explain the area but directly above the window on the plastic which is kind of indented. Not sure if that helps.
#33
ORIGINAL: BabyH
#34
My crack has just now appeared...I will call my dealer and have my name put on the waiting list for the new and improved version, whenever GM comes out with the replacement.
#35
I have it too, but on the inner part of plastic, not outside. the guy at dealer saw it but I was anaware of a list I need to get on to get this replaced ?? I thought once a recall happens they will mail all the people who purchased H3s for replacement
#36
had to have both front rail replaced because the joints cracked ( plastic molding on side of windshield )
had to have my radio replaced
dealer put a dent in my passenger front door , now they have to send it in for body work
#37
ORIGINAL: Dennis
..Maybe this will help explain where the suspect crack may appear...My dealer also said that GM is working on a fix..Known problem, so be patient!
ORIGINAL: BabyH
#38
Did I ever mention I was a perfectionist and ****?'..So I dabbed a little silicone (black) gasket maker in the crack for now to hide it..Looks ok to me for now, untill GM gets off their ***'s and fixes their mold/material problem with these rails...Dealer said today that they have about two dozen or more H3 owners with the same problem waiting for the GM fix...No news when though[:@]
My quick Fix...
The stuff I used..
My quick Fix...
The stuff I used..
#39
I found the crack today as well. I'll do the silicone trick until there is a recall.
#40
my windshield is cracked, wonder if i'll get any help from the dealer . . .[sm=bicker.gif]
