Problem - rough idle and stall 1st start of day only
Old 02-22-2011, 02:09 PM
branstone's Avatar
Default Problem - rough idle and stall 1st start of day only
so just recently, starting like 3 days ago i have a new problem. This only has happened so far on the first start of the day. When i start it it starts fine, then starts to idle very rough , and loosing rpm, even pushing accelerator, the engine just bogs down and stalls. Then I restart it and it runs fine from then on. This has happened now 3 days in a row. Yesterday when it did this and stalled there was smoke from exhaust and smelled very rich.
any ideas? no check engine light.
Old 02-22-2011, 04:36 PM
2wheelmonster's Avatar
to me it sounds like an egr valve stuck open, but if the smell goes away then it might be a clogged exhaust or maybe an O2 sensor is going bad
Old 02-22-2011, 09:34 PM
tate2326's Avatar
mine has done this before... let me know what the shop says.
Old 02-23-2011, 02:59 PM
branstone's Avatar
I haven't taken it to a shop, it didn't do it this morning.
Old 02-28-2011, 10:06 AM
branstone's Avatar
Soit turns out that cylinder one has an issue could be the rings, they did a compression test at the shop, compression goes down on dry test but stays the same on wet test, so they think bad rings maybe.....and lots of $$$ bummmer.
Old 03-05-2011, 01:42 PM
Tater Salad's Avatar
Crap!!! Mine does the same thing every morning. Gassy smell too for about a minute. I guess I'll just drive the pee out of it until it dies for good.
Old 03-05-2011, 02:34 PM
White08H3's Avatar
Looks like another 2006 problem unfortunately.
Old 03-05-2011, 03:52 PM
Zipthelipp's Avatar
I doubt its the rings, head maybe. I also have an 06' with over 58k on it and after everything I read about 06's I'm just waiting for my head to go. Anybody here with an 06' without a head issue??? Good luck Branstone keep us posted.......
Old 03-07-2011, 06:37 AM
dafihummer's Avatar
Yep, I have a 03/06 build..65K..no probs..mind you, dont know if anything has been done on the head while the car was still in the US [ car shipped here in Oct 2010 when I bought it] ...But runs fine now...
I had a stalling problem, turns out coil 1 had water in it and was rusting away inside..
changed that and all is well..dont know where the water came from ?..
all 5 plugs are fine..
Old 03-07-2011, 07:39 AM
RKSmith163's Avatar
The water came from around the fake hood vent. There is a TSB on it. I guess that is a mute point now if you took in in for the recall which glues it down and should therefore seal it pretty well.
Quick Reply: Problem - rough idle and stall 1st start of day only
