Problem installing the Amplifier (H3)
I have everything set up in my H3, the only thing is that I need to run the RCA Converter from the stock radio wires, or stock speakes wire (same thing). But the problem is "Which color is it". I have 12 cables coming out from the harness in the rear door panel. And I really dont wanna break anything neither mess around with the door panel interior just to get to the speaker inside and find the rights wire's color from speaker when I can find it here. Please if someone have installed and Amp. Let me know what wires color did you use from the speaker/radio. I really appreciate it. Thaks a lot.
RE: Problem installing the Amplifier (H3)
i havent done a H3 before, but with my ram, i eliminated a few wires by tracing them out, and then the left over wires were left. then i took a cheap speaker i had sitting around, and stick the wires in the terminals until i had it figured out. you could also check with the dealer. or try alldata, or stop by a local shop and see if they have alldata you could use.
dangle
03-20-2012 08:03 AM
ockie
09-12-2007 03:57 PM
