Powersteering, Transfer Case, Transmission fluid amounts
Want to change my powersteering fluid to Synthetic not sure how much I need, any idea??
Also Transmission and Transfer Case..looking to know how much I will need to buy..
a little help would be great.
Already running Synthetic engine Oil and Differential Fluid.
RE: Powersteering, Transfer Case, Transmission fluid amounts
If you're just pulling the transmission pan and letting it drain, you wont get more then 5 qts out. Its gonna be pretty much impossible to get all the fluid out unless you flush the tranny so I would put back in what you're taking out. I think the transfer case holds around 2. Im not 100% positive so I would get 3 to be safe.
ORIGINAL: Misfitflesh
-6 qts Dex-6 when dropping tranny pan
-12 qts Dex-6 when doing complete tranny flush including tq converter
-Transfer case takes 2 qts Dex-III (Dont use Dex-6)
-Front diff hold 2.5 qts 75w90
-Rear diff holds 3.5 qts 75w90
-cooling systemholds 17.2 qts dex-cool (OEM fluid is fine but I add 2 bottles Redline water wetter)
-Power steering and master cylinder hold less than a quart each
