Power Window Mystery
99 H1 window question. Windows from the drivers master control raise and lower all windows. All other window switches will not raise or lower. Yes, the drivers master control switch is set to on. I've checked the interior window fuse and replaced it just to be sure, but still nothing. What am I missing?
It's probably the switches themselves. You can pop them out and try to "rebuild" them (they come apart, and you can adjust the contacts). Otherwise buy some new ones.
If you have a working switch, try putting it into a location that doesn't work, and see if that does the trick.
does your alarm automatically raise your windows? I think I'm having window issues due to the ECM. All of my windows work correct except for one that doesn't work through the switch on the door. But last week that window would roll down everthing time I started the car. Found out my ECM has some bad wiring.
hummerhack
12-17-2014 02:25 AM
