Possible lighting solution for the H3
[size=2]
I remembered seeing these in the 4WP catalog but couldn't find them on line.
Never used either product, so I cant attest to the efficacy of the kits, but here they are....
Gunner_45
http://www.innovadd.com/BB.main.page.html
http://www.innovadd.com/BB.apps.7.07.html (Application guide)
http://www.performanceproducts4truck...spx?pid=111652
http://www.performanceproducts4truck...spx?pid=111318
The Brite Box
Works with stock headlights and headlight bulbs
Made in USA
All vehicle headlights have two distinct beam patterns: low beam for close range illumination, and high beam for long range illumination. In most vehicles, when the high beams are activated, the low beams shut off. The resulting choice of "near" vs. "far" illumination compromises safety and comfort. The Brite Boxâ„¢ illuminates the low beams when the high beams are activated which allows 100% of the lighting potential of the vehicle to be utilized. The Brite Boxâ„¢ provides an even carpet of light that stretches from near to far improving safety. The safety benefits and circuitry of The Brite Boxâ„¢ has been proven in millions of miles of over the road testing, and is used by law enforcement and transportation companies. The Brite Boxâ„¢ also comes in "FLC" (Fog Light Control) versions that keep both the fog lights and low beams on with high beams for the ultimate in illumination! The Brite Boxâ„¢ features easy plug in installation (in most vehicles).![](http://www.innovadd.com/Images/BB.large.jpg)
or
Bulbzilla/Fogzilla Headlamp/Fog lamp Upgrade Kit
Increases low beam capabilities by 70%
Can also be used to upgrade fog lights
Plug & play installation
[font=tahoma][size=3]If you’re looking for a quick and easy way to get more light out of you stock low beam headlight or fog light, the Bulbzilla/Fogzilla upgrade kit is perfect. Each kit is a simple plug and play wiring harness that allows you to covert your regular 9006 low beam headlamp bulb to a 9005 high beam bulb. Some vehicle fog lamps (depending on application) also use a traditional 9006 bulb and can be easily upgraded! When upgrading to a wit
Gunner_45
The Brite Box
Made in USA
or
HummerDriver
17
09-01-2010 09:28 AM
viking66
08-20-2008 11:33 PM
HummerGuy
05-08-2008 02:02 PM
littlehummerboy
01-24-2007 04:18 AM
