Plexiglass sunroof glass replacement?
Shattered my sunroof driving down a gravel road.
I have Toyo M/T 35X12.50xR18, they kicked up a rock and smashed my sunroof
My question is, has anyone ever replaced a sunroof glass with plexiglass??
Not sure, but I don't think it's perfectly flat (has a roof contour). You'd never be able to match it unless it was. If it IS flat, you'd be better off with polycarbonate. Much stronger/scratch resistant than Plexiglas. It's the stuff used for cycle helmet visors, & bullet proof glass.
Edit.....stick with the OEM tempered glass. In an accident it breaks up into little square pieces, where a plastic could break into dangerous shards.
New glass and have insurance cover it since it will likely be expensive. Then install a gobi without the sunroof opening.
That problem is exactly why I got rid of the rancho lift with the tires sticking out, One gravel road and it's raining rocks.
Thanks for the replies!
I had some glass companies quote a new glass as high as $1500!
But my insurance is going to take care of it, thankfully.
@talusfan: did you go back to stock height and tires?
Gunner_45
34
04-08-2007 12:06 PM
cost, glass, h3, hummer, install, installation, lexan, moonroof, orlando, plexiglass, repair, replacement, roof, sun, sunroof
