PLEASE help H1 will not start
i have a 2001 H1 6.5 turbo diesel
car stalled on me started stalled.........ect
got advise might be fuel filter.. Replaced it and it started for about a day drove it about 20 miles parked it at home two days later drove it out went about 600 ft and it stalled... and did not start anymore.. left it in drive way ....
Car turns but will not start
Plugged in a computer and said Shut off fuel solenoid was the problem Replaced it and still nothing
Now no codes on computer
then was recommended to replace the PMD which i did ....... still nothing
then some one recommend to replace the lift pump which i did and still nothing......
i put some GAS in the air intake turned over cranked as i had the key in the start position at times got black smoke then white smoke out of exhaust but would not remain on
Please help
Please help
Thank you for the response.
i have not changed the filter again but i have checked the filter and it is still clean, even the old one seemed clean.
i checked the line where the Fuel goes into the Injector Pump and comes out with good pressure. Is it possible for it to be bad gas and still start a little because i did get a black smoke then white for a few second while i was holding the key in the start position when i put a little gas in the air intake.
Thank you for response....
it sounds like th injection pump is having a issue internally. you most likely have a bad cam sensor or a fuel drive solenoid and both are in the injection pump. remove it and take it to a diesel injection pump repair shop the deals in stanadyne injection pumps. they can bench test it and tell you what the issue is. everyone that i have worked on that came down to the pump being the issue, i pulled the pump and sent it out to be repaired and the engine would fire right up when i was done with it.
Any way i can check my self to see if ip is working?
TxHummer07
03-22-2015 11:02 AM
JensH2
12-14-2013 02:27 PM
simota1
17
07-30-2012 05:02 AM
goad2k8
01-18-2009 06:03 PM
