Pitman idler arm change any tips??
Im changing my pitman and idler arms tomorrow. Ive heard you must remove the steering gear to do so. Anyone know any tips to avoid doing this and speed things up a little. I will be changing both again and adding the cognito kit in a few weeks i am just trying to get my H2 rolling safely for the weekend. It looks tight under the pitman arm. Dont think a conventional puller will fit which is what I have heard. any tips would be appreciated thanks guys.
removing by torch
most front end shops have to heat or torch the ones that come off hard .
have been a ase tec for over 15 years , there is no problems with using one if the other metheds dont work , just have to be carfull...mike
success
We changed the idler, pitman, and both tie rods without special tools. Took half a day. U may need a bar to come down through the top on drivers side. Be careful to line the spline back up correctly or u will be getting a new steering box as well
Charles
Charles
H2Miami
10-20-2014 12:21 PM
Man1nboat
06-25-2013 11:20 AM
herecomesthepain
08-14-2010 08:45 AM
