Picture Of Fuel Cap Bezel Cover Removed?
Who has a photo the fuel filler plastic bezel cover removed showing the clips? I tried many times to get the dang thing off and it just does not want to come off ---pulling at the bezel at the clips (effort here to put a new fuel door on). I see looking underneath looking up the fender there are threes clips but not sure exactly how the cover goes on these clips. I tried hammering a bar on the bezel cover inside the fender but that did not work either....any help appreciated.
There was an old thread on how to install fuel door with photos but the link in the thread does not work any longer.
Be carefull, it will probably be easy to crack the fender if it's real cold. From the outside, put your fingers over where one of the clips are located, push down (toward the ground) as you pull out on the bezel. As you get one or two disengaged, the rest will be easy. Yours may have double sided tape holding it on. If it does, it isn't going to be easy.
WGW
WGW
