Piaa lights
Piaa lights
i want to add piaa lights to the brush guard. my guestion is
does any one know how to connect them to to the bright lights.
i want to use them as runnig lights. i only want them on when the
brights are on. thanks
RE: Piaa lights
I would find the wire that is the source for the brights first. Shouldnt be too hard to find. Just start at the headlight assembly and work backwards with a test light..(I made one out of a needle and one of those cheap 12v neon lights for inside a ricer.) You only need to find the + wire from one headlight. Splice into it and then run that to the PIAA relay that came with the lights. You could even put a switch between the headlights and the relay in order to "arm" your rigging. Or get a 3 position switch and that way you can have it always on, off or automatically on.
mastercraft88
01-06-2011 08:20 PM
lucky19942001
05-03-2009 11:32 AM
mastercraft88
08-12-2008 12:11 PM
sanddragger28
02-18-2008 12:29 PM
