Parking brake - break !
Well Tom I have a 5 speed and you NEED to use the parking brake (not everyone has an automatic trans).
Plus the pereodic use of the parking brake on an automatic with rear drum brakes will adjust the tensioner (we don't have to worry about that with our HUMMERs.
yeah, i wasnt promoting non use, just relating my "training"!
the self adjuster i forgot,,,they didnt work much either and id crawl under and wiggle that wheel and it made a big difference.
btw,parking in reverse works pretty good xcept on a real hill huh?
anyway in flatland its just one less thing to mess with,like shifting!. i got lazy and spoiled by autos. couldnt find stick shift stuff for the 460!
I refused to take it back to the dealer after my handle broke awhile back.
Can't see myself sitting there for a day while they swap out the parking brake system
Even if it was free.
I pulled the now bare wire cable end out and held it with some vise grips.
I then used my PC11 epoxy and glued the handle back onto the cable end.
(PC11 epoxy is a marine grade epoxy)
I made sure the handle was horizontal and let it sit over night.
It has worked great. Now the handle is held securely and not just by two plastic tabs
Now I can pull on the handle like a lab monkey on amphetamines
You should be able to get it at most hardware stores
Two small blue cans (catalyst/resin) full cure in 24hrs.
Even sets up under water.
Old rule of thumb with epoxies, the longer the cure time, the stronger the hold.
The H3 manual states you should push down on the e-brake pedal and then pull the e-brake handle. I guess it saves wear in the parts. Also prevents that clunk noise of release
The reason I had to use epoxy, was the plastic tabs were broken and there was nothing
the handle would grab or snap back onto.
Good luck
After a day of getting muddy or heavy rains and road grime I find my e-brake cables are crudded up and it makes releasing the e-brake difficult. I lube the cable and all goes back to normal. A crudded up e-brake cable was why I pulled the release handle off in the first place- just trying to pull harder to get it to release.
Shocked! new owner 08' Alpha, same thing pulled right off in my hand today and then fell under the pedals.. Such a strong vehicle and such a poor design for this! Very disappointing, looks like the epoxy may be the way to go unless the handle needs to be off for the dash panel removal..
Mine has held up fine since the repair.
If you look at the plastic handle you can see it was only held on by to small detents.
I surprised it lasted as long as it did before the repair
Good luck
