Parasitic battery drain
Hi:
I am down in NM with a dead battery. I have a 2008 Adventure H3 with the 3.7L, Auto Trans.
The battery was replaced in CO two months ago and never gave me a problem.
Using a digital multimeter I have determined that I have a 320ma drain that I cant seem to find. I have pulled each fuse one by one and no change.
Is it possible that one of the relays is stuck? I assume that to check that, I have to pull each relay one at a time?
Thx!!
Thx!!
i find 110 ma to be normal. so i guess you could pull , oh there is another onstar fuse , i heard,never saw, behind the ?batt ,?
or,pull relays!btw i have a jeep with a ??batt problem. i put a kill sw on the batt,lazy way out.it seems that someone had trbl with the radio stuff,you might get in there asnd pull some plugs??
Disconnect the positive and negative cables and set DVM to ohms scale. Test across the leads and check to make certain you get a reading. Zero is short. Mega is open. 3-5 ohms or more is ok.
Check the trailer wiring for a short under the back end.
Chris
Chris
I found the drain...it was two Hella relays that power the (4) Hella 500 roof lights. The lights themselves were not on, but for some reason the two relays are "on" the whole time. I flipped the light switches in the opposite position and I could hear the relays "click" off. Drain dropped to 70ma.
I will have to check how it was wired as there is a fuse before the relay and there is no fuse in the fuse holder so the relay is getting 12vdc somehow.
Same Crap
Radio took Crap first.... No volume control, can't change to CD... Periodically beeps and periodically will work correctly for a minute or two.
Then had a series of delayed reaction starts (i.e. turn key to start ... Nothing release key to ON/run and after a second or two engine fires normal and starter releases as it should.
Then after sitting for 2 days NEW battery DRAINED condition... Had to break in with coat hanger and jump. Charges right up. Leave it for a day ... It's dead. Am hearing potential for ignition switch or relay problem. Interested in any other ideas or tests My non electrical skill set wouldv permit? Thank you All.
You likely have a bad ignition switch. Since your radio is toast, I would not rule out a short in the radio causing a draw down either. Remove the radio and see what happens?
What kind of battery charger are you using? If you are using an old school charger for a few hours..... then you are not charging the battery to 12.9V +.
dognut
04-21-2011 09:58 AM
