P0332 Knock Sensor
P0332 Knock Sensor
Just completed an engine wash and now my check engine light came on and it seems to be the Knock Sensor; is there a quick fix or just need time to dry? Looks like if need to be replace it's a 3-4 hour job; does any have pictures of the location of this item(s) or lesson learn about this work.
I had the same problem about six months ago. I ran through some fairly deep water and the next day the check engine light came on. The only cure was to have the knock sensor replaced. I didn't attempt it and it was a little expensive to replace it. Around $400. There are two of them and you might want to consider replacing both. Good Luck with it
madmayo
04-07-2015 03:22 PM
darrenz
10-07-2013 08:52 PM
C31322
09-11-2013 03:27 PM
Kimmea
08-01-2012 07:47 PM
