P0171 maf sensor concern help needed please read and help live data info included
HI thanks for reading i recently got the code
P0171 engine runs too lean B1 S1
any way no vaciom leaks found after i changed the intake manifold still the same problem
today i changed the exhaust manifold due to crack with new OEM new one i have reset the code p0171 now the trem fuel level is like
Short fuel trem is 7%
long fuel trem is still 24% just like old times
HO2S sensoer changed by new one code is still there
now the important thing is i before this code is throun i used carb cleaner to clean the MAF sensoer i don't know if that contaminated or spoiled it
here is the test for the MAF data
reference range for MAF on MaxiDAS says the range is 0.00 to 0.66 (lb/s) ok>my car the maf at idle reads 0.01 lb/s and at 3000RPM reads 0.03 lb/s
my question is . is this normal??????????????? tell me what to do please.
i am going crazy i already through 740$ for exhaust manifold 250$ for intake manifold 65$ for HO2S its driving me crazy please help
hummer h3 89000M 2007 LLR 3.7l I-5
no miss fire records on cylinders
Correct me if I am wrong
Carb cleaner is very caustic and is not intended for cleaning electronic componets.
CRC MAF cleaner or equivalant is all that should ever be used.
ONLY after the MAF is unpluged should it be cleaned and don't use things like rags or compressed air on it.
ONLY after the MAF is completely dry should it be pluged back in.
BUT MY QUESTION IS TELL ME ITS THE MAF BECAUSE THE RANGE IS GOOD OR BAD
REFRENCE RANGE (0.00 TO 0.66 lb/s)
my maf is 0.01 lb/s at idle 640 rpm and is 0.03 lb/s at 3000RPM
