Overhead Module
Old 04-14-2008 | 10:37 AM
Lampooner's Avatar
Default Overhead Module
Hi,
I have 2006 H2 with sunroof. It has the small overhead module between sunroof and windshield.
I want to add a couple of things near it that require 12V DC to work, like a GPS and backup camera.
How do I gain access to the inside of the module, It has a couple of hex screws near the windshield end of it. Do these come out and the unit drops down?
Second question, I would like these units to be pluggable into 12 volts. Any suggestions on what type of connector to use ie., cigarette lighter plugs, small 12V coaxial jackets, etc..
Thanks in advance for any assistance.
Old 04-14-2008 | 08:39 PM
blackstangs281's Avatar
Default RE: Overhead Module
I believe Bob has pic's of his taken off............................he'll be here soon
Old 04-14-2008 | 11:24 PM
DWP99's Avatar
There are 2 screws that go straight up into the overhead console, they are fairly close to the windshield. Take them out and the console falls down. Look at the grab handles on the "A" post. thereare 2square plugs, prythem out with a screwdriver and the handles come off (no screws) then you can pull the "A" post covers off to run wires up to the overhead console. use caution when running the wires. The drain tubes for the sunroof are also in the "A" post, if they get crushed or pinched the sunroof won't drain properly and you will fill the head liner with water the next time it rains.
Old 04-15-2008 | 04:00 AM
Yeah, Pretty simple for the overhead console.
Like DWP99 said, there are only 2 screws holding it up. Top of Pic!
Old 04-15-2008 | 05:32 AM
Lampooner's Avatar
Thanks all for the sponses. Confirms what I thought, but will move forward now with more confidence.
Old 04-15-2008 | 07:59 AM
dwaxman1's Avatar
well done Bob
Old 04-16-2008 | 03:15 AM
You mean....WELL DONE DWP99!!!!
Old 04-16-2008 | 06:44 AM
dwaxman1's Avatar
DW99 explains it well, I was more talkng about the blinging overhead!!
Old 04-16-2008 | 08:51 AM
calif phil's Avatar
Anyone know what bulbs are in those map lights? I want to get some LED bulbs. I just installed the PUTCO Led kit last night and it does not include those or the door panel lights.
dwaxman1's Avatar
194 will work
