Oil Leak Massive...Hummer 6.2L
Oil Leak! Brothers and Sisters i need help! 08 6.2L SUT with massive oil leak at rear of motor. Local dealership diagnosed rear main seal, R&R and leak continues Local dealership then R&R oil pan gasket, then cooling line on drivers side at transmission. You guessed it, still leaks if not worse. Cannot verify the work done, oil pan looks clean though. Any thoughts?
Cannot see leak until motor is off, within a few minutes oil appears on the ground My 5th SUT, 2nd 6.2L, and I've never has a single mechanical issue. All suggestions welcome, heck I can't even trade in with this situation...
OCFDfyrfytr
OCFDfyrfytr
OCFDfyrfytr
OCFDfyrfytr
Also these motors have a history of issues with the two part rear main seals. There is a special alignment tool for setting the position of the seal but GM now specs replacement of the rear cover which comes as an assembly with the seal installed to prevent this issue. Might want to check to see if they did this. Where the rear cover meets the oil pan there is about an 1/8" gap that is (should be) filled with gasket material. When I just replaced our oil pan two weeks ago the material had worked out of the gap and I cleaned it up well and put additional gasket sealer on these two spots to prevent any issues.
RyanH3
30
11-19-2015 04:53 PM
hummer07
11-18-2008 10:46 AM
