On and Off-road Performance: Dune Grappler
Old 06-19-2008 | 10:05 PM
Post Release's Avatar
Default On and Off-road Performance: Dune Grappler
Dune Grappler
The Nitto Dune Grappler is based on the award winning technology of the Nitto Terra Grappler. The Dune Grappler is designed for the enthusiast that spends time on pavement and desert trails.
When the tire needs to be taken off-road, the tread pattern and large contact patch allow the tire to float over loose gravel and sand. The Dune Grappler also has large sidewall lugs and triple- reinforced sidewall construction to help prevent sidewall punctures.
The unique tread pattern reduces on-road noise that you normally get with aggressive off-road tires. It also has strengthened tread blocks that give the tire high-speed stability.
Select sizes are available in higher load ratings for towing.
Click here for Nitto Dune Grappler sizes.
Dune Grappler
This PostRelease(tm) is part of an advertiser-supported program that sponsors Hummer Forums. This program delivers relevant news and announcements as posts within Hummer Forums.
DTS62284
09-18-2010 02:56 PM
Post Release
06-20-2008 10:32 AM
Post Release
06-19-2008 10:04 PM
Post Release
06-19-2008 09:55 PM
topcarbon
07-31-2006 10:50 PM
