Non-OEM Roof Bars, quick fix FYI
In case anyone was thinking about buying a set of these, here's what I found. I bought a set of the Chinese made cross bars from Amazon because I couldn't see spending $600+ at the stealership. The covers don't sit 100% flush with the base, but I expected that. They do lock and have a key, so I don't think the covers are going to blow off. The biggest problem I found was when you locked them down in one of the roof runner notches, they were extremely loose. I bought eight 5/16" X 1-1/4" nylon washers (two for each latch). Then pulled the latch assembly apart by pushing out the pin holding the handle to the latch, pull the spring off the latch, place two washers on, replace spring and reinstall handle.
Now they lock into the grooves very snug, cost me $2.50 and took about 10 minutes.
Been running these for several years. They hold up just as well as the OEM's and the covers haven't come off.
Mine were a tiny bit loose depending on where at in the track I tried to latch them down. I just pushed down on one side of the rail a tiny bit where I wanted them to sit to create some tension and haven't had an issue.
ultraclassic01
05-19-2012 05:53 PM
SundownAudioNY
09-06-2011 03:02 PM
theBroken
01-19-2010 07:38 PM
