Noise Diagnosis
Old 05-27-2007 | 08:26 PM
HingHum's Avatar
Default Noise Diagnosis
Since off-road trip last weekend I have noticed a strange beating noise (think shusch, shusch, shusch etc - like dirty bearings??) which occurs only when I let off the gas tocoast or slow down. The noise is only heard between 1500 and 1000 rpms (typical coasting rpms I guess) and seems to be transmission or drive shaft related. If I put the vehicle into neutral the noise dimishes significantly. If I drop back into drive (without accelerating - still coasting), the noise is enhanced. If I am accelerating I don't hear the noise. I played with the brakes thinking dirt or pebbles might be stuck on top of the calipers and grinding against inside wall of rims, but I don't think that is it. My best guess is dirt or grit got into the bearings of the front or rear drive shaft connections, dirt in CV joint(s) up frontor I knocked the transfer case putting front or rear drive shaft out of alignment.
Any ideas??
Also, if I did this damage while off-roading will the warranty cover repairs?
Thanks.
Andy
Old 05-27-2007 | 08:32 PM
dilo2001gt's Avatar
Default RE: Noise Diagnosis
did you damage any drive shafts ?
Old 05-27-2007 | 09:16 PM
blackstangs281's Avatar
Can't say for sure, but that noise sounds like a inner CV joint. Take it to the dealer for them to check out. They should cover it.
Old 05-27-2007 | 09:37 PM
HingHum's Avatar
No Drive Shafts damaged. The plate protecting the Transfer Case was bent up a bit but nothing out of the ordinary.
Old 05-27-2007 | 10:21 PM
azz7772's Avatar
quote "Since off-road trip last weekend I have noticed a strange beating noise " maybe you ran over a sharp tailed grouse
Old 05-28-2007 | 12:00 AM
Xtreme's Avatar
Sounds like the typical worn u-joint/cv-joint 'replacement required-type' noise...sans the 'clunking' sound when placing the transmission into gear. Name:  71ccd41c.gif
Old 06-01-2007 | 05:01 PM
HingHum's Avatar
I thought I'd report back on this one.
I took the H3 to the dealer and after a full day of diagnosis, I just got the call that they will replace the front differential and see if the noise goes away.. Good to see that the GM warranty is good!!!
Old 06-01-2007 | 07:35 PM
TINKED's Avatar
They had to replace my front diif too... but I had no noise ....no warning....broke 100 miles out of town and had to be towed....Warranty covered mine as well....mine pierced the casing, oil gushed out .....Hope that fixes your problem !
[IMG]local://upfiles/2323/0013BC933C7648A293DEEB25B2350EFC.jpg[/IMG]
Old 06-01-2007 | 11:17 PM
mfish's Avatar
What the hell is a sharp tailed grouse??
ORIGINAL: azz7772
Old 06-02-2007 | 03:58 AM
ORIGINAL: mfish
ORIGINAL: azz7772
I had to Google it!!
